don't you people have anything better to do with your days than spam useless crap on websites (including this one) all day, every day?
geez..
if you ask me, this thread should be closed PERMANENTLY
It's a casual way the more social forum members can talk to each other through out the day. Perhaps as a general chat thread some guidelines need to be set out, but I don't see why it would have to be closed permanently.
geez..
I agree with the first part, def disagree with the second, here is where we get to ask the hard questions, if it fails for a response then you know to start a thread about it, if you can sometimes wade through the spam, that is.
And just to change the subject, Im glad I dont live in Russia.
More than one hundred coal miners are confirmed dead in the Ulyanovskaya Mine disaster, Russia's worst mining accident in a decade.
look i have nothing personal against those members that frequent this thread..
my issue is the reputation that comes to SAU as a result of actions of those who have a tendancy to whore threads, eg the events of those who got so bored that they went over to other forums and tarnish SAU's image
when i see posts like "in for page 1", i just don't know why people bother even posting, wasting bandwidth, and actually making everyone who reads it lose functioning neurons
the way i see it, the best solutions are:
1 - close this thread, and just head on over to the wasteland section of SAU
2 - post all your MSN usernames in your signature and just chat on MSN.. this is a dedicated program for chatting
forums = for posting threads and sharing knowledge
chatrooms/instant messaging = for random chit-chat
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
