no plazma man is a differnt plenum, the greddy is cast and the plazma man one is welded together. From what i know both are of good quality and workmanship, but my car had a greddy one already thats all.
thanx Troy.
the plazma is the same design as greddy, however as you pointed out, it's welded instead of cast. Probably due to the fact greddy have unlimited funds and produce many more than plazma....I would think that the greddy's would have less imperfections because of this though.
What about a just jap greddy copy :)
my swaybars should have arrived today and dan was taking the motor out and apart tonight.
there is a couple of weeks wait on my coilovers though
be interesting to see/hear whats gone wrong with it
ahh bummer, well u wont need them for awhile it seems :)
not tlakin bout that, i know he can build em quick, but its the running in of the rings that is the 'long' part
Just fill the sump with used diesel oil and put a brick on the loud pedal. Instant run in. leave brick for 5 minutes or explsion. which ever comes first.
i'd like to see you do that if u've just built a 15k+ motor :)
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
