Could be the onions i had for lunch.
gl with your car toy. It must be murder trying to sell a 33 atm.
Which is why I didnt try too hard with mine :)
Good luck anyway mate..
On another note anyone got a couple of 235/45/r17's they wanna sell me! I need two for a roady or a whole set of stocko rims with roadworthy rubber they wanna lend me? For a week or so?
Lending tyres is like lending women, they both come back f**ked.
Should have heard her talk dirty to me on msn then
hahahaha... you are just too fluffy, I can't help it!
She told me about some sexytime dream
I got hard over it
hahahaha eww!!!
that wasn't a sexytime dream!!! Like I would have told you one of those!!!!
hahah thats a goody! I am not a rude person though and if someone was to lend me some I wouldnt f**k them as I treat peoples stuff how I would expect mine to be treated. Anywho....are we baiting the right hook to get your attention!?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
