hmmmmz, no you don't it's only a one of payment as well to get the plates.....
yeah, one off payment to get the plates...then a yearly fee to keep them....like NSW...
In QLD its a once of fee....forever!
For a Supra, there black one looks good
Yeah it looks heaps tough!
One of the HPI DVDs has a few of their cars in it...and the owner wears a parachute material hat.......with a straight as brim........and it is fluro yellow
HAHAHAH HAPPY TIME
I just nutted everywhere
thats cool
haltech has somthing similar
I asume its on the haltech web site? Does it look like the Sard one? I used to think my dash was the ducks nuts, i need me a Sard style thing. Ive seen em, just never mounted in a car
Since when, we where paying a year fee for personal plates "IDG000" for years
dunno, how long ago was that? Nobody I know pays a yearly fee for personalised plates in vic. It's just the one of payment to begin with.
Wrong!
same as vic except 5x the price, so gay, the plate I want is avaliable up there too :)
Wrong!
We gave the Vic personal plates back in 1991 when we moved to QLD, however a family member who has had their personal plates since the early 80's is still paying a yearly fee I believe.
I think you'll find what keegs said is correct, unless you can see otherwise on the Vicroads web site, I know Mario? with GTR700 said he wasn't going to ever give his plates back when the rego came off "GTR700" as technically he never owned the plates, just paid a once off to get them, plus a yearly fee, plus rego costs.
hmmm interesting, well someones getting stooged. I asked a few of my friends with custom plates and one even showed me his rego renewal letter cos he just got it and none of them pay a yearly fee for their plates. They have probably all got the plates post 2000ish.....
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
