Sup Col, hey, anyone know anywhere that will give a 21yr old an 18k unsecured loan for 4-5 years with weekly repayments of ~100? :pwned:
Arent you buying a R33??? YOu can have mine for 15..that should bring the repayment down a bit!!! :pwned:
Sup Col, hey, anyone know anywhere that will give a 21yr old an 18k unsecured loan for 4-5 years with weekly repayments of ~100? :P
Rob a bank maby :ninja:
Arent you buying a R33??? YOu can have mine for 15..that should bring the repayment down a bit!!! :P
15k thats a top price :pwned:
1st mod: rip that farking muffler off and replace it with a proper one :P
:P
Im not touching that one... Its between admin and the user...
forum drama off the port bow
Ya :pwned:
Help help I'm being oppressed!
Anyway, yeah, waiting for a reply from someone about a loan, don't think they'll do anything though.
Might give the dealers finance person a email and see what they can offer me.
Edited by Hell Fire
You complain about a rattly clutch but want a screamer pipe and a loud exhaust....fecking ricer
i like to hear what the car's doing, with that farking whisper quite exhaust u cant hear anything!
and i only complained about them rattly clutches to fire u lot up :pwned:
hey col how come you aint bashed the user in the for sale thread sayinara??
News to me, you should hit the report button to direct my attention towards a thread...
which admin?
Just admin allright, I have distanced myself from this matter weeks ago I have nothing more to say about it.
Ive stayed out of it and I wish to remain out of it. That is all I have to say about this matter.
Get a hearing aid grandpa :pwned:
says the man who'se older than i :pwned:
alrite alrite i wont ask anymore sheesh
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
