I am selling raffle tickets for Capricorn Drivers Support Network.
The prize is a $50 fuel voucher at the retailer of your choice, Australia wide.
Tickets are $1 each.
Will be drawn on the 16th of June, 2007.
Proceeds will go to the club, which supports:
* The Yaamba Driver Reviver
* The Capricorn Helecopter Rescue Service
* Angel Flight
* The Rockhampton Base Hospital Childrens Ward
Please contact me if you wish to buy a ticket or 5 =D
Man I am that boerd I am actually considering going through the qld section to see what is going on in the se corner :teehee:
Yeah?....Well I'm so bored I have started to eat my own arm off!
Man it's hard to type with one hand.
OMG :teehee: Dan, sup?!?!?
I was going to contact you sometime, my clutch is going to be needed to be replaced sometime, it's a R32 GTR box, and wont go over ~200awkw.
I want something my wife can drive easily, but still be strong enough to handle rpm limier launches every now and again......... suggestions? cost? Can I pay for it with my virgin rear hole?
Sif virgin rear hole!
I'll grab some prices for you on Tuesday.
This weekend has been messed up. Haven't got to do any of the things I needed to get done.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
