so i could convert to solid lifters...or what size is max on hydro lifters.
9.something mm lift, tiny tiny cams compared to a solid head
u could convert it to solid, jhh does it for $400
Me.... Cams....
No, the car will be gone in 6 weeks, why would I put cams in it???
caus i reckon u wont sell it lol. and to turn ur car from a power skidder to a useable powerd car :)
hey guys,
my diff is rooted! along with my clutch... s133gtst
looking at my options,
-Shimming
-New Diff (thinking Kazz 1.5 from slide)
-Second hand stock
-Second hand gtr
there are a few second hand gtr diffs floating around are they an upgrade over my stocker and do they fit up? I think noel was saying he had a gtr diff in his.
whats the best way to go, I can afford a new one but i would much rather spend my money on another part of the car, also fitting it myself.
Cheers,
Dan
myeah i want something from with power range from 3000 - 9000+
and i want a rotary idle mostly...:)
hey guys,
-Shimming
-Second hand stock
-Second hand gtr
Cheers,
Dan
either 1.5 way or gtr diff....shimming myeah dont think it would last as long.
I'm wiht oblivion!!!
if you get a 1.5 way or a gtr diff, you can kind of forget about it.. once it's done, it's done! where as shimming your current one, you'll more than likely have to do it again a few months down the track!
I've just ordered my 1.5way from slider, after months and months of umming and arrrring over the issue!
I want a turbo right now, So I can just look at it, fondle it, blow in it and get hypnotised by the whirling blades. Polish it. Show it to the cat.
sigh
hahahaha
hey guys,
-Shimming
-Second hand stock
-Second hand gtr
Cheers,
Dan
Yes i do have the alsd option in my 33. (as does Andy) That said i dont think it would be an easy conversion to make. there is the electronic side of it along with the hydraulic set up to consider as well. If your car didnt have the alsd from the get go i think you might be better off looking at the other options.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
