BTW with that summons, I thought there was such a time limit on them, like speeding fines, 28days to pay sorta crap, not 1 year on wtf thats a joke
There is a time limit, if after 28 days you havent paid the ticket or filled it in to take it to court it roll's onto SPERS as you no longer have a choice. Neither of those options where taken..
Year later I get this
Edited by Nismo_Boy
Long story short this letter shouldn't have came... They were told Media or drop the ticket over a year ago
Sounds like they are taking the Court (and media) option. They always take that long to respond with action when dealing with fines that have had complaints/letters sent in with regard to matters such as that. Case and point my fines with that cop who was off duty, who acted like a tool and learnt a lesson for being ghey.
When you send a letter contesting the fine or the like, it's taken that you are taking teh court option, usually they send you another letter saying pay the fine though....although that is the pleading guilty part of the summons.
And as per normal I will continue to make it hard for them. The thing is... The fine was handed to Steve and he was told to deal with it, I don't think there were any correspondence in regards to it.
It should have went to SPERS...
Nothing was sent like that.. It was more like my verson of events on paper the ticket and a verbal pull ya f**king head out of your ass and fix this shit
yeah, oh well....when you get your license back you'll be on your opens and you'd only lose 3 points for that anyway...who cares...fight it for fun or just pay the fine, either way it wont really affect you.
true date of issue was on my opens anyway
Interesting twist:
The summons was served wrong, technicality number one. Only a small one but mistake none the less.
The paper work is wrong, the paper work appears to be in another car when in fact it was the fine in Darrans Charade
*goes back to finding all the paper work/research*
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
