PM's about what?
work, tiffs party, parts for sale.. and general yada yada lol..
mechanical shit yo
remember he's an ex toyota mechanic :sorcerer:
such a hater shane.. but thats ok we cool...
found me a rock bottom price on my PFC..?
I believe he said it made 360 kw's at the rears. dont doubt it either. Damn strong car.
Hey Noel, at the moment its only making about 320Kw.
Just got back now mate, could not break that 13 sec pass tonight. Definately wrong tyres they have no grip on them anyway up for some new ones i think.
Still Cant believe that f**ken Vetec Honda beat me. That was when i lost traction 1st 2nd and 2nd into 5th :) back into third, LOL.
Thanks for comin and making the effort jumpin over ur back fence :mrt:
Thanks for comin and making the effort jumpin over ur back fence :(
well atleast now u know uve got a bit to do to that rear end to make it run decent times!
what kinda rear end gear are you running atm?
At the moment the set up is not for drag thats for sure. Tien coil overs which are hard as, and 285 Pirelli P zeros.
Im not an expert on these coil overs but can you make the ride softer.
noel prolly suggested this last nite, but them tyres at 18psi will help alot
yeah u should be able to adjust them a bit, u gotta wind the dampner knob on them. you know what model teins they are? they've prolly got ~10kg springs in the rear lol. the drag spec coilovers i've seen (the HKS ones for example) have ~4kg rear spring rates!
u getting any/much axle tramp off the line? best way i found to see if a car has axel tramp, was to bag em up in the wet in a straight line, the wet road will exaggerate the tramp if there is any
other than that, u could spend a few dollars on more suspension goodies
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
