They sound like ass, have the worse oil squirter set up for the cams and dont make that much top end.
They are light and punchy down low. boring :(
haha i knw.. i was examining mine when i put my RAS in.. atleast they have wells for the cam holders.. shit i forget the name.
does the job and wont clog with regualr servicing.
gosh you boys should take it to msn
lol
and u should buy some stuff off me. lol
we are on msn but more fun here
hey bud, im shane, and im no emo hahaha, i to tease them kind haha
wanna meet up on queen st head to rebel sport buy some irons and go to town.. literally.. :(
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
