It's my pick because rather than cutting costs by blending into polyalphaolefin base stock for its motor oil, Red Line Oil only uses superior poly ester-based products—resulting in lubricants that are extremely stable at high temperatures while providing superior film strength at lower viscosities where more power can be produced.
Motor oil.
Red Line synthetic motor oils are a superior strength oil, designed to provide the highest degree of protection and cleanliness for your engine. Red Line lubricants contain polyol ester base stocks, the only lubricants which can withstand the tremendous heat of modern jet engines, which makes our motor oil a necessity to properly lubricate a hot running engine or a turbocharger. More importantly, Red Line motor oils can significantly reduce engine wear, which means a longer useful life for your engine. Unlike other oils that break-down quickly, thus having to be changed at small intervals, Red Line has superior long-drain capabilities. Read about how Red Line synthetic oils have been shown to last 40,000 kms in field tests.
Race oil.
Red Line has a complete line of race oils (5W up to 70W) that work under the demanding conditions of high-performance driving. Red Line Race Oils have gained a reputation as the ultimate racing lubricant. Marketers of other lubricants unsuccessfully claim to be “as good as Red Lineâ€. Our lubricants are used by teams who understand that improved performance and equipment durability is the key to winning. Our race oils are made with the most thermally stable synthetic base stocks available and provide the best high-temperature lubrication and a higher film strength than any petroleum or synthetic marketed. Red Line Race Oils provide more power than an oil of similar viscosity, while providing much more protection. Each reduction in viscosity grade allows 1–2% more power.
Redline can explain it better.
Basically protects engine better. Make more power. Oil is more thermally stable. Only oil that can lubricate hot metal.
Redline are the only oil manufacturer that can PRINT that they are better than all others on the market because they can actually prove it.
now THATS's what i call a good post, it certainly doesnt belong in whoretown :sleep:
Also....ask R33_Racer why he uses Redline in his track car? I'm sure he'll tell you it's because it's a far superior product.
...either that or because his dad tells him to lol.
....But if you ask his dad, then, he would definately say that....definately.
they were using motul lemans (up until the last race)...
...they may be changing, whow knows
so bitch, what's 12ltrs of this fang-dangled redline gonna cost me?
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
