if you run a greddy plenum it will open up the top end and it shouldnt nose over...probably need a good exhaust manifold too (6boost). Our gt30 .82 rear went to 320rwkws without water injection and it pulled all the way to 8k redline. Remove all possible restrictions in the bolt ons and you can run the smaller puffers further to the edge without losing power.
Im up to 332rwkw now on 21psi and still have stock cams...
So a goal of 350rwkw (which to be honest is too much for a daily driven car) is easily achieved from the Garrett GT30R also know as the GT30/40...
Im at 21psi by 4000rpm btw, so its quite streetable, just farking stupid round town when it comes onto boost and jumps sideways... :unsure:
So i turn the boost controler down to 16psi where it makes just on 280rwkw and thats far easier to handle round town... :O
Im at 21psi by 4000rpm btw, so its quite streetable, just farking stupid round town when it comes onto boost and jumps sideways... :O
So i turn the boost controler down to 16psi where it makes just on 280rwkw and thats far easier to handle round town... :P
thats promising. i said noel's car will break the 400rwkw mark, and if ur results are anything to go by, he should do it fairly comfortably :unsure:
all noel's has to do, is pick up 69kw from 4psi more boost, cams & massive headwork, piece of piss i reckon
Easy.
if my bitsa can can 490rwhp/365rwkw on a td06-25g with t78 wheels on 1.5bar (3800rpm) Noel will piss it in
Fkn A doggie, shouldn't be a problem. Andy got 306rwkw on 18psi i'd like to see them bump it up to 22 or so and see what he can get. He doesn't think it'll be much of a difference but with the new fuel pump and shiz he shouldn't be running out of fuel like last time. I'm trying to convince him to go back to chiptorque, best tune we ever had was from them.
theres heaps of stuff on youtube, theres a clib with arabs drifting a Carrera GT and a McLaren Mercedes SLR....
I too am watching youtube clips...
cept i'm reminiscing so mine are in the form of
http://www.youtube.com/watch?v=wor-Z4SyWCg
http://www.youtube.com/watch?v=Qmve365Ti1k
かわいらしい さくら - MISS KITTEH! says:
haha and I wasn't a fan of human nature
except for one track which was very BSB/nsync
Josh says:
some one will think im queer when they see this history
bahahah it will just confirm rumours
Josh says:
they're only true when im drunk
Josh says:
lol
z so i'd find you at the beat then?
hehe
Josh says:
they sell cheap drinks
Josh says:
quiet u
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
