Its a movie set in Spartan times, I just watched it last night and Im impressed, its been a while since I have seen a movie where I was totally engrossed but I couldnt not watch its awesome. **warning scenes of gratutious violence** 10 outa 10 from me
how farked are 32 gtr boots? why would nissan make them so farking small :nyaanyaa:
Cos ashun women are smaller than euro babes hence they are easier to abduckt and fit in the boot of a 32. :laughing-smiley-014:
this is what im gonna have to do now. will need to cut the floor around the cell & tank so i can drop the tank down enough to get the correct fall for the fuel filling pipe from the std filling location in the guard. Also need atleast 22" height for the dry sump tank
haha.. yeah.. u doing ur inner or outer shane. stuff using nissan though.. get some repco ones and a seperator.. tkaes 10mins per outside corner to do on AE corollas.. hehe :sorcerer:
yes, i shoulda kept the boat, aka 33 :thumbsup:
learn quick..
wtf u talking bout? :nyaanyaa:
no space saver shane..
will prolly have it mounted under the car after the cell goes in
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
