ahaha..ok..
hmm tossing up the idea of buying a a/m FPR or seeing if the standard one works with 740cc.. which sound be flowing 60% at 200 but im going for 240kw. what brand.. had a malpassi before.. not impressed.. perhaps sard..?
perhaps ill try with the standard..any suggestions
*clears throat*
ha ha
Who wants to drive my car to a good drag time? I couldn't be bothered ha ha
i'll do it.
and i'll try not to blow this one up :)
noel...old man and me are going to keep the greddy mani on for now and then later do a straight manifold swap and do some back to back testing to see dyno and real world difference between greddy and plazmaman on a built motor....how does that sound for ya? We were arguing about it all afternoon....stupid old man, annoys the hell out of me sometimes. Just need some egt sensors in every port or lambda sensors for every port to monitor afrs for every cylinder. Hopefully we will cover most bases, not only will it help with tuning it will help log the results in terms of airflow for each cylinder and whatnot.
Completely random...but i rememeber that thread we were talking about whats better and whats proven and blah blah blah...so here is our chance to actually do that for everyone.
pyro's in which side, intake or exhaust? i remember reading on here somewhere about them and the general consensus was that they'd interfer too much with the air flow
Your man cans are growing bigger by the day. You'll be sitting down to piss next. :laugh:
i thought he already did :)
ahaha..ok..
y do u want to adjust the fuel pressure? if u've got good injectors and a good fuel pump, u shouldnt need to play with the pressure.
doesnt have to be full on racing...even just sprints or the time attack days even top gear.
drag and drift is all over way too quick....wasnt meant to rhyme either.
haha or maybe it was... :D
Edited by r33_racer
nah prolly just a T04Z. My tax return wasnt quite as large as I would have liked
That list on his msn is his list.
that'll still make ~700bhp. well so dan reckons. haha always the way isnt it
ahh i see, we mite see it running in another 5 years :D
well he has to do my engine, check your clearances, and the million other things that he does to help people out.
apparently some tuners prefer being able to dial in more fuel pressure.. and also i wank the wank factor :sorcerer:
just gonna run 740cc nismo direct fit. i forgot what brand pump i got. im ordering the turbo thru aaron 3071R 56 (slide) unless someone recommends otherwise..
maybe ill talk to dan
ahh i see, we mite see it running in another 5 years :)
ahaha coming from u shaney poo.. LOL :D
he's a wanker, get dan to get them for ya
u know its bad when i pay ppl out for build times lol
thaqt would be a good idea, he has the best garrett prices around, also i might be selling my GT2876R .64 T25 flange????
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
