Since when? Linky link please.
Plus I can easily beat that price anyway. lol. Sif you'd look anywhere else.
thats without actuator too. only like 80 cheaper than aarons..
and im sorry for looking elsewher dan SORRY :laugh: dont punish me.. i checked out ur site dan but no mention of the 3071R... :)
Bathurst 4-7th Oct
Indy 18-21st Oct
Whats wrong with your google???
google broken..
The only downfall of the standard reg is flowrate. I think they are limited to 230L/hour or 600rwhp
Why have you picked 740cc injectors? They can easily supply you with enough fuel for 500rwkw. 240rwkw should only require 550cc and even then you won't come anywhere near their max. It's all in the tune. Get youself a Nismo, SARD, HKS or Tomei intank pump (they are all the same pump). They are the best for direct fit and good for up to 550-600rwhp
yeah i realise that. 740cc would be overkill but so is a 3071R on 1bar only to get 240kw.. when the SR dies ill forge it up and hit up 300kw.. the injectors and 3071R should be able to support that.. so all im doing is leaving room for improvement..
the fuel pump i have in ther is some aftermarket one. forget brand but was told by the workshop that fitted it supports 500ponies. ill pull it out to see what it really is.
marki, i've always said the wet is like liquid horsepower to the kiwi's :domokun:
bahahaha... yeah quite different.. havent had the 180sx in the rain before.. rain is quite rare here..
So you will be going 360 in the 180 soon ?
haha i did a 180 in the 180.. haha slide.. slide slide.. ok too much.. spin bahahaha...
ahaha also i went round a nice hairpin.. and 2 commo drivers wer on the side of the road having a smoke.. saw me.. and they just dropped ther jaws ahaha.. i came prob 1 foot from the damn pole though.. :sorcerer: showed them how its done...
this is whore town so no flaming bahaaha :laugh::)
farken rofl
speaking of ur car sub, hows she goin mate?
Yeah not to bad mate, fitted my Nismo fuel pump the other day the car felt a bit flat so i checked the plugs they were black as.
Im a bit confused on what plug to use. I was using BKR7E i dont think the car liked them. Im back with the BCPR6ES now i will see how they go.
and how is yours comin along.
just go some coppers, u foul them alot so no point wasting 120 every time u change plugs. also ring danielson aka shrek aka dan for advice on which plugs to use
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
