If it the one I am thinking of I think you will find it quite gone
Lol worst tyres ever, luckily you are only destroying them
yeah its gone.. need some standard RB25 cams..
well they wer 70% now.. around 5% and delaminated heaps.. i melted the insides quite bad.. and i can see how much neg camber on the back i have.. the outside look like 60% and insides are shit.. thats just from 2 hours of practice. fark my exits are getting good.. its my damn entrances and a lil clutch slip...
not too mention a bit of understeer it gets sometimes..
what r u laughing at?
BTW did i tell u ive got that tow truck booked for tomorrow morning for u to do that roll cage? :)
No worries mate...ill start and finish it after work today, 4-5 hours should be plenty of time, might even have enough time to have it painted also. haha.
Spare box you wont need...just a spare set of dog rings.
Hi guys, Whats happening?
had a great weekend went out to Norwich Park mine near Dysart (3hrs west of Makay) for a work thing. the coal mine had an oepn day was good to go see all the man machines!!! went in a dragline was tuff as got lots of pics will put up later
where do you slide Mark???
Street or track?
atm industrial area nothing special.. :D i never do anything stupid anywher near other traffic.. thats just not right.. and never near other residential areas.
start hitting the archerfield track soon. as soon as i fix this understeer problem.. :3some: any ideas.. thinking castor rods and 7 on thefront.
i have a set of rb25 cams...
i told a girl to f**k off she cant hang with us all the time and she got shitty.. if i told shane he would try to hump me.. why r girls different/?
caus u smell funny? :3some:
ur a good worker michael, u'll go along way :rofl:
bahaha when i rang that bloke to ask about boxes, he asked how u n ur dad were going with the box, and he said they'd last alot longer if the driver knew how to shift properly :D
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
