Ive got some RB25 cams as well, and a shit load of tyres for ya Marki they are just a little worn on the outside but have plenty of tread on them, but there all 18s. range from $20 to $30 each.
Edited by subzeroR33
Here ya go Shane i got the dog box for ya ive even thrown in the dog. ;)
bahaha.. hi5!! :sorcerer:
could be interested.. my sponsor gives me cheap.. but.. he wants that damn ass sticker on my car for me to get cheap cheap..
i need 17s.. 205??? 215s...?? skid rubber.. or if u knw of any S13 rims chuck some rubber on them ill take them off ya..
^^ dont agree with the fag bryn..
Shane how much u want for them standard cams..
name a price and their urs big fella. its not like i have any use for them lol
trader rate is goooorn but i note the warn rate hasnt. LOL :P
theyd make sure the wanring system was working, but they couldnt give a flying fark about any other 'features'
GO SAU!
rofl
GO SAU!
rofl
picked up those track rims today bish, dumb f**ks left the rubber on them, rears about 30% fronts about 70%. these things are so farkin light, made in japan but i cant find anything other than jawa on them. gotta get some gutter rash off one of them but they clear the brembos by at least 10 mil. SWEEEEEET!
siff mark, im keeping you company, im just waiting for you to invite me over so i can taste that cute cock of yours.
ahaha ur emoticons on msn lol
hopefully they put an age cap on members.. over 70fark off!!
pics noel.. wanna see.. should weigh them..
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
