Uhmmmmmm, my engine was molested by youths while parked at a gridiron game and then I drove it home. The water line from the thermostat to the heater was sliced but not all the way through. It blew while on the Centenary near home and the temp gauge flickered. Got it home and it died in the driveway and it had well and truly cooked. Towed to Richo's and it is awaiting an engine transplant. Hoping that insurance will come to the party. Police report has been made but no promises. If JCI don't come through, I am off elsewhere for insurance!!!
oh shit.. what a bunch of wankers.. cant believe that...
could u smell coolant.?
I rate the places I stay on the food they have, yes im that shallow.
I rate the hotel service on how quick they replace the soap/shampoo that i steal.
I rate the weather on what I have to wear to be comfortable.
I rate everywhere i stay and give very detailed descriptions to Nay when I get home, but I never make it sound too good.
Im in Toowoomba every 2 weeks for work so i eat a shit load of steak... :P
Steak capitol of Australia with out a doubt...
I went to rocky once, where they have bulls and cows as statues all round town and everything. I was expecting the best steak i have ever tasted and so I said to a mate, take me to he best place in town. So we went to Hogs breath, i mean their good dont get me wrong but I can have Hogs Breath anywhere...
Was disapointed with the steak in rocky (the beef capitol of australia, but not the steak capitol).
But to make up for it, they have wonderful seafood, but not as good as cairns... :google:
Thats cause they send all the good stuff to Japan and Korea.....Unless you intercept a package bound for there you have never had a great steak
The consumers here pay for being tightasses
Hey Bunta!!! Enjoying Kingaroy!!!!
Home now
Anna will see you at Allstar tomorrow
The hose dumped it straight under the car, so no smell. First I knew something was wrong was when the cars behind me dropped way back due to smoke!!! :P
did the corporate id for 1824 beef and AACo they sent us a esky full of their jap export beef - it was orwgazmik!
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
