Yeah financially it's about as close to a sure thing as we're likely to find. The place is ~5 years old but I suspect the previous owners were a bit OCD lol
LOL, thats what ya want. Keep this one and use it to get another later on?
Yeah the market was just starting to slump when I sold mine! As it was I sold to my sister in law's brother so I sold it to him a fair bit cheaper than I would have otherwise, but got a bit extra back by selling a couple of parts separately.
Do I want an AC Schnitzer short shift?
yes, and u also want the abundment of carbon fibre too!
shane dont have a spare.. try danny boy.
farking tried to punch in my tracking number for couriers please and it didnt work..
i've got 3 spares, 2 however have some surface rust :D
Where's a decent keyboard warrior when you want one?
u rang? :sorcerer:
I stopped in a JBC cars at strathpine which are well know to only do high quality performance and collectors cars...
Had a look see at a few and saw this R32 GTR for 15k stock as a rock with no scratchs and the interia looked about right for its age, but yeah 15k is nuts...
He said he just bought a supra out of japan with the works (800hp unit) for under 25k landed, all he has to do is the usuall and you got yourself a 800hp supra for under 30k... The market has fallen to pieces, I asked so hows R34 GTRS going, he said thy are probablly the only car still fetching good money. But he said they do pop up from time to time under 42k FOB which is just nuts...
I hate cars :P
No no i dont :D
So north lakes shopping centre is getting JB Hifi in the new section, hopefully before XMAS :P
Thats 7 store openings in QLD this half... Id be looking at shares...
Yeah I had to get into the back section of the shopping centre and someone told me I would have to go down the side of the estate and drive back in along one of the service roads, anyway I ened up at the golf course :D
yeah apparently you had one...never saw it did we.... :P:D
btw, gtr's rock my jocks :O
:no:
So north lakes shopping centre is getting JB Hifi in the new section, hopefully before XMAS :D
yeah but i'm poor so that aint gonna happen anytime soon, unless you want to donate to the abuse of Rohan's Bank Account Foundation??
you wont get a reciept nor any back with your tax.
Ordered, the carbon will have to wait however.
whats your model and series year etc?
hahaha
Yeah we went for a look in the new bit of the shopping centre, ended up driving around in between all the piles of steel, scissor lifts, security guards etc lol... they didn't have it fenced off. We made our escape by finding an open gate near the demountables the workers are staying in...
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
