Yeah financially it's about as close to a sure thing as we're likely to find. The place is ~5 years old but I suspect the previous owners were a bit OCD lol
LOL, thats what ya want. Keep this one and use it to get another later on?
Yeah the market was just starting to slump when I sold mine! As it was I sold to my sister in law's brother so I sold it to him a fair bit cheaper than I would have otherwise, but got a bit extra back by selling a couple of parts separately.
Do I want an AC Schnitzer short shift?
yes, and u also want the abundment of carbon fibre too!
shane dont have a spare.. try danny boy.
farking tried to punch in my tracking number for couriers please and it didnt work..
i've got 3 spares, 2 however have some surface rust :D
Where's a decent keyboard warrior when you want one?
u rang? :sorcerer:
I stopped in a JBC cars at strathpine which are well know to only do high quality performance and collectors cars...
Had a look see at a few and saw this R32 GTR for 15k stock as a rock with no scratchs and the interia looked about right for its age, but yeah 15k is nuts...
He said he just bought a supra out of japan with the works (800hp unit) for under 25k landed, all he has to do is the usuall and you got yourself a 800hp supra for under 30k... The market has fallen to pieces, I asked so hows R34 GTRS going, he said thy are probablly the only car still fetching good money. But he said they do pop up from time to time under 42k FOB which is just nuts...
I hate cars :P
No no i dont :D
So north lakes shopping centre is getting JB Hifi in the new section, hopefully before XMAS :P
Thats 7 store openings in QLD this half... Id be looking at shares...
Yeah I had to get into the back section of the shopping centre and someone told me I would have to go down the side of the estate and drive back in along one of the service roads, anyway I ened up at the golf course :D
yeah apparently you had one...never saw it did we.... :P:D
btw, gtr's rock my jocks :O
:no:
So north lakes shopping centre is getting JB Hifi in the new section, hopefully before XMAS :D
yeah but i'm poor so that aint gonna happen anytime soon, unless you want to donate to the abuse of Rohan's Bank Account Foundation??
you wont get a reciept nor any back with your tax.
Ordered, the carbon will have to wait however.
whats your model and series year etc?
hahaha
Yeah we went for a look in the new bit of the shopping centre, ended up driving around in between all the piles of steel, scissor lifts, security guards etc lol... they didn't have it fenced off. We made our escape by finding an open gate near the demountables the workers are staying in...
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
