Fighting Josh would be like kicking a puppy...... he is so cute and cuddly.......
And Josh I am working at home today until 11.30 then off to the Academy to work on some training modules for a class I am teaching next week. It is actually my day off but I am a dedicated Prison Officer who gets to teach other Officers Control and Restraint methods, Chemical Agent Delivery Systems (gas) and what I am teaching next week, Emergency Response Team Leader training, you know, batons, shields, riots, etc.... :)
Farken crazyness! How many c**ts you beating the shit out of, like OZ style on SBS lol. Reckon I'd be someone's bitch at the jail? Or is that just hammed up for tv lol.
Oh an dave, I want a hug now
- n- now th- that don't kill me
can only make me stronger
I need you to hurry up now
cause I can't wait much longer
I know I got to be right now
cause I cant get much wronger
man I’ve been waitin' all night now
that's how long I’ve been on ya
Hows this for you "homo" liking then... Something for the older folk...
My, my, at Waterloo Napoleon did surrender
Oh yeah, and I have met my destiny in quite a similar way
The history book on the shelf
Is always repeating itself
No, wiffle balls are made of a heavy foam that doesn't do too much damage but can be thrown like a baseball. When thrown hard enough, you can get it to elongate and therefore curve in flight. But they do hurt like a bitch when they hit you!!
Yeap, just saw it on google...
I thought it must have had somethign to do with the ball as thats just not natural...
Im thinking this guy would have to be morth millions in major league baseball with that tallent...
Cool non the less, check out the ice bombs... I think you will like it...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
