Fighting Josh would be like kicking a puppy...... he is so cute and cuddly.......
And Josh I am working at home today until 11.30 then off to the Academy to work on some training modules for a class I am teaching next week. It is actually my day off but I am a dedicated Prison Officer who gets to teach other Officers Control and Restraint methods, Chemical Agent Delivery Systems (gas) and what I am teaching next week, Emergency Response Team Leader training, you know, batons, shields, riots, etc.... :)
Farken crazyness! How many c**ts you beating the shit out of, like OZ style on SBS lol. Reckon I'd be someone's bitch at the jail? Or is that just hammed up for tv lol.
Oh an dave, I want a hug now
- n- now th- that don't kill me
can only make me stronger
I need you to hurry up now
cause I can't wait much longer
I know I got to be right now
cause I cant get much wronger
man I’ve been waitin' all night now
that's how long I’ve been on ya
Hows this for you "homo" liking then... Something for the older folk...
My, my, at Waterloo Napoleon did surrender
Oh yeah, and I have met my destiny in quite a similar way
The history book on the shelf
Is always repeating itself
No, wiffle balls are made of a heavy foam that doesn't do too much damage but can be thrown like a baseball. When thrown hard enough, you can get it to elongate and therefore curve in flight. But they do hurt like a bitch when they hit you!!
Yeap, just saw it on google...
I thought it must have had somethign to do with the ball as thats just not natural...
Im thinking this guy would have to be morth millions in major league baseball with that tallent...
Cool non the less, check out the ice bombs... I think you will like it...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
