sif you guess if from that boyo....you would know a passat if it drove over you.. :)
my car has an umbrella holder...its called the back seat, or passenger.
my car also has a finger holder....do i need to tell you what that is also called???? :blink:
i need an 18mm spanner Marki, dont know where mine has gone.
yeah ill bring one.. might i ask wher on a friggen nissan do u need a 18mm spanner..???
ah thats ok, just a cruiser and nicely done.
just trade it in on the r36 when they come in, and then come round and take me from 0 - 100 in 5.6 secs.....mmmm..
i bet it wont do 0-100 in 5.6 and if it does that would put most of the GTRs around to shame..
nah, I'll just wind up the boost!
...and hello safety fuel boost knock cuts that all euro ecus and control sensors now have.. they are basically a giant rule book on 4 wheels.. too many sensors and electronics.. everytime u do something something will negate it and go fark no.. unsafe.. and bye bye warranty yada yda
nah i didnt shane :( i didnt, asian loookign girls arent my thing.., now, time to go find me a lady boy
.... :blink: poof....
I LOVE ASIAN CHICKS...
bahah gold
hiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii anna :domokun:
got the 180 at home yet???
ohh Sil80 FTW..
sean and i are currently looking for a S13/180 for a project.. just want it in semi running order with a manual box dnt care if its NA but mst have transferable rwc..
I happen to know u suck at putt putt :P
i got a hole in 1 in the last one i went to.. hole 6 to be precise... and it was the sweeper too ;)
Yeh my mom always told me it was rude to finish first :laughing-smiley-014: but i just can't help it :)
LOL.. thats funny as..
i would have paid u to go piss on it
lol... watch the cop insides face lol
I would have paid to watch you piss on it. :D
so would i.
OK GUYS.. $20 to anyone who finds me a decent 180sx to put my RB25neo in..
must be manual.
must be able to register in my name.. asap.. as in RWC and paperwork..
must have clean chassis.
im looking for stuff like this.
180sx CARSALES
of course cheaper the better.. ill also throw in some free parts too if its a good base car...
THANKS
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
