no you shouldnt....you should give it to me......nah but seriously keep the SR if you want to slide.
yah im thinking that.. the engine is the neo u knw the R34 one with 55kms.. i dnt knw many RB25neo 180sx only ghostys thats it..
but yeah thinkin of makin a 2 car drift team mine and mine.. well sean wants the RB in it.. i think i shall test the bottom end of the SR.. :laugh:
nope. no chance to yet.. but the slide dyno day i got some suprises for y all.
is that ur opinion.. ya dick im asking for ur opinion.. as i have another 180 that wants more power and i could be different and put the RB in.. i was planning on putting it in a CA 180 but a SR 180 came along.
seriously, if u put the rb25 into the 180 ud make urself look like a dick (well a even bigger one :laugh:) caus u've portrayed ur opinion that sr's belong in 180/sil's and rb25 belong in rb etc.
ya feelin me?
My Phalic references refer mainly to the love of my own. its kept me very happy for very many years and will continue to do so.
Patience Squizz, yo azz will be handed to you soon enough. :laugh:
I look forward to a proper thrashing, makes it all worthwhile in the end.
barina..??
ohhh scary its like waiting for death to get ya.. wait isnt that whats gonna happen?
Methinx its going to happen to you a whole lot sooner than to me.
Muiltiple shanking coming right up. :laugh:
ya feelin me?
has anyone felt ya..?
ive put RBs in silvias before. how will this make me look like a dick ive portrayed the opinion that Std SR pwn std RB 20 and 25s. the 25 has more head room in the end.. but in standard its quite capable. ur jumping the gun again. thing is i have a spare healthy engine here and a car that needs more power.
...no shit
smoke and mirrors?
barina it is.. u suit the image.
sure why not make ur already extremely overwight skyline even MORE overweight :thanks:
ouch, dnt be hatin....we cant all have 34's :banana: but i mean hey, that lil bike looks pretty quick :) mite be able to take on some of the skool kiddies wit that one, yay!
Edited by RusH_
ouch, dnt be hatin....we cant all have 34's :thanks: but i mean hey, that lil bike looks pretty quick :) mite be able to take on some of the skool kiddies wit that one, yay!
well u dont become wold leader by crusin in a 34 thats for sure ;)
:banana:
well u dont become wold leader by crusin in a 34 thats for sure :)
:thanks:
neva planned on becomin world leader, but out of curiosity what does a world leader drive? airforce one? i dont think its a 4 wheeled bike :banana:
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
