I want a supercharged M3.
This man know's what its all about.
word on the street was u had aids...words on the street now is u certainly do have aids
Driven many M3's? Raced many M3's? No. Sit down.
Is there a name for what's wrong with you?
Red nut with a computer?
oi fochers. whats the power delivery on the supras like? a tt rz im talkin (94 model, so no vvti)
270rwkw, 264 9.0 cams, std turbo's. 2nd gear useless?
savage.
interesting.
are the stockers reliable? i.e what are the chances of turbo wheel departing and entering cat/motor
comparable to the skylines?
sequential system is quite lowly and has a fair bit of restriction on them most owners replace the sequential system..
CT turbos are fairly good. US version JZA got steelies.
yeah the whole driving of your car can lead to problems like that
much safer in the backyard :(
bahaha OWNAGE...
i chuckled..
watching oceans 13.. its not as good as i thought... just started but..
i rather a JZX100 chaser... 1JZ and only 5 spd no getrag is that correct josh? lil lighter and 4 doors.
Yes, all manuals are 5 speeds. JXZ90 is lighter then JZZ30 Soarer. I'm not sure what the JZX100 is like, but I'd be safe to say they should be lighter, if not the same.
This is a good forum. http://www.jzx100.com/forum/
interesting find josh is it aussie site.?
if i didnt buy another 180sx last week i would prob get a JZX100 next year.
Hi Melvin.
Depends how the go peddle is used and what tires are on it.
The one I drove just had an exhaust and FMIC, was lots of fun for a stock car. Smooth power, punchy down low.
Shits on skylines.
nothing is reliable. Chance's are the same as any other factory made ceramic turbo.
You can tickle 1.1 - 1.2bar out of them from time to time if your nice, but thats not an everyday thing.
i'd go col stylez. i.e china copies & ebay specials :sorcerer:
none. i've seen youtube videos. thats enough eveidence for me to back up my claims re eurotrash
thats Mr Ginger to you
There is more to car package, yes total package then outright power.
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
