I want a supercharged M3.
This man know's what its all about.
word on the street was u had aids...words on the street now is u certainly do have aids
Driven many M3's? Raced many M3's? No. Sit down.
Is there a name for what's wrong with you?
Red nut with a computer?
oi fochers. whats the power delivery on the supras like? a tt rz im talkin (94 model, so no vvti)
270rwkw, 264 9.0 cams, std turbo's. 2nd gear useless?
savage.
interesting.
are the stockers reliable? i.e what are the chances of turbo wheel departing and entering cat/motor
comparable to the skylines?
sequential system is quite lowly and has a fair bit of restriction on them most owners replace the sequential system..
CT turbos are fairly good. US version JZA got steelies.
yeah the whole driving of your car can lead to problems like that
much safer in the backyard :(
bahaha OWNAGE...
i chuckled..
watching oceans 13.. its not as good as i thought... just started but..
i rather a JZX100 chaser... 1JZ and only 5 spd no getrag is that correct josh? lil lighter and 4 doors.
Yes, all manuals are 5 speeds. JXZ90 is lighter then JZZ30 Soarer. I'm not sure what the JZX100 is like, but I'd be safe to say they should be lighter, if not the same.
This is a good forum. http://www.jzx100.com/forum/
interesting find josh is it aussie site.?
if i didnt buy another 180sx last week i would prob get a JZX100 next year.
Hi Melvin.
Depends how the go peddle is used and what tires are on it.
The one I drove just had an exhaust and FMIC, was lots of fun for a stock car. Smooth power, punchy down low.
Shits on skylines.
nothing is reliable. Chance's are the same as any other factory made ceramic turbo.
You can tickle 1.1 - 1.2bar out of them from time to time if your nice, but thats not an everyday thing.
i'd go col stylez. i.e china copies & ebay specials :sorcerer:
none. i've seen youtube videos. thats enough eveidence for me to back up my claims re eurotrash
thats Mr Ginger to you
There is more to car package, yes total package then outright power.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
