agreed.. but i can remove the stickers, and he said he'll take $23k without the rims (which means if i squeeze him, $22k). then i can spend $2k on some nice 18" rims.. the other thing thats gay is the giant f**koff tacho and shift light he has to the right of the steering wheel... that'd be going the day i got it.
i figure
$22k for car without rims
$2k for some rims
removal of stupid guage and installation of boost guage $100
momo steering wheel $200
Electronic Boost Controller $400
and ill prob spend $1k on the sound system
total $25.7k for a GTR setup pretty close to how i'd want it.. down the track,
$1k for some coilovers
i think its still running stock clutch so prob another $1k there once it lets go (though he says current one is in 'perfect' condition)
p.s. i sent him a PM and got the following reply:
Hey mate, few questions from a serious buyer
how much power did it make ? who tuned it (if it was through Gavin, i presume Matt Spry)
what boost turbo's running ?
stock suspension ?
what condition is the gearbox in ?
stock clutch ? what conditions it in ?
deatils on sound system ?
would you be willing to sell without the rims (ie. i get my own rims put on and you keep/sell yours) ? i dont mind them, but if i recall correctly, more than 2" above stock wheel size is a defect..
Im also on the gold coast, so easy to check it out too.
cheers
just give me a call and i will answer all questions
i will take $23000 without rims also
270kilowatts
1 bar boost standard turbos
gearbox perfect
clutch perfect
sound system is kenwood with panasonic colour cd player with remote it is also pre wired for a sub in the boot also
does 270kw at the wheels sound right for stock turbs @ 1 bar with no cams ?
Yeah 35k is a tad bet steap...
Ive been looking very hard over the past 3-4 weeks and found some real bargins coming through the auctions in japan... :rolleyes:
Saw a Series 3 R33 go for 26k (stock and clean) an R34 GTR with some accident damage go for 36k (damage looked like just boot lid, rear bar and tail lights)
In short the Aussie dollar is strong, get out there and shop around you will find heaps of bargins getting out there...
i would steer well clear from buying a gtr from someone on the goldy with shopping list stickers and 20's!!!!
i highly agree
I want this one: 1997 GTR
Regularly serviced every 5000Km at Allstar Tuning systems where I am told this is one of the best condition GTRs around
that above comment would be more than enough for me to steer well clear of that car
and lol @ that guy asking 35k for his stock purple 33 gtr :rolleyes:
but its got fulley sick rims brah! mmmm 18x11's
If i actually get one next year I will probably go throught imports101 some smick micely modded 97 models close to the 30g mark coming through
Does no one know that term? It is along the lines of awesome and such.
mexicans and the like have rather strange ways of expressing themselves
i watched the condemed lastnignt now thats was preety cool!
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
