agreed.. but i can remove the stickers, and he said he'll take $23k without the rims (which means if i squeeze him, $22k). then i can spend $2k on some nice 18" rims.. the other thing thats gay is the giant f**koff tacho and shift light he has to the right of the steering wheel... that'd be going the day i got it.
i figure
$22k for car without rims
$2k for some rims
removal of stupid guage and installation of boost guage $100
momo steering wheel $200
Electronic Boost Controller $400
and ill prob spend $1k on the sound system
total $25.7k for a GTR setup pretty close to how i'd want it.. down the track,
$1k for some coilovers
i think its still running stock clutch so prob another $1k there once it lets go (though he says current one is in 'perfect' condition)
p.s. i sent him a PM and got the following reply:
Hey mate, few questions from a serious buyer
how much power did it make ? who tuned it (if it was through Gavin, i presume Matt Spry)
what boost turbo's running ?
stock suspension ?
what condition is the gearbox in ?
stock clutch ? what conditions it in ?
deatils on sound system ?
would you be willing to sell without the rims (ie. i get my own rims put on and you keep/sell yours) ? i dont mind them, but if i recall correctly, more than 2" above stock wheel size is a defect..
Im also on the gold coast, so easy to check it out too.
cheers
just give me a call and i will answer all questions
i will take $23000 without rims also
270kilowatts
1 bar boost standard turbos
gearbox perfect
clutch perfect
sound system is kenwood with panasonic colour cd player with remote it is also pre wired for a sub in the boot also
does 270kw at the wheels sound right for stock turbs @ 1 bar with no cams ?
Yeah 35k is a tad bet steap...
Ive been looking very hard over the past 3-4 weeks and found some real bargins coming through the auctions in japan... :rolleyes:
Saw a Series 3 R33 go for 26k (stock and clean) an R34 GTR with some accident damage go for 36k (damage looked like just boot lid, rear bar and tail lights)
In short the Aussie dollar is strong, get out there and shop around you will find heaps of bargins getting out there...
i would steer well clear from buying a gtr from someone on the goldy with shopping list stickers and 20's!!!!
i highly agree
I want this one: 1997 GTR
Regularly serviced every 5000Km at Allstar Tuning systems where I am told this is one of the best condition GTRs around
that above comment would be more than enough for me to steer well clear of that car
and lol @ that guy asking 35k for his stock purple 33 gtr :rolleyes:
but its got fulley sick rims brah! mmmm 18x11's
If i actually get one next year I will probably go throught imports101 some smick micely modded 97 models close to the 30g mark coming through
Does no one know that term? It is along the lines of awesome and such.
mexicans and the like have rather strange ways of expressing themselves
i watched the condemed lastnignt now thats was preety cool!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
