yo shane do you know if noel sil has his stock inlet manifold?
ummm im not sure if he has it laying aorund still or what. i'll check it out for ya
sau go down for anyone else
yep
You got a buyer Andy...
Any deposit as yet???
I got another crack at it this morning, waiting for finance responce for buyer...
Does not one have 20k in cash these days... ???
No deposit yet that will come in the next discussion i think!
very nice - black?
when can i grab the plenum? what suburb you at?
No must be white
Anytime after Sunday, I am in Yeronga
Anyone in the gold coast area interested in being a formal car this coming thursday evening?
A lady sent an email to the r31 skyline club but not many of the r31s around are 'flashy' enough to to impress the kiddies :-P
The car that was taking her son to the formal pulled out at the last minute.
"Pickup time from Arundel/Coombabah at 4.30pm
and then off to Royal Pines Resort at Carrara. It should only take 1 - 1 1/2 hours
tops"
Let me know if your interested as i have a contact number
god im funneh at 3:30am!!! :P shane
anyone got a big f**k off breaker bar i can borrow on sunday/today harmonic is supposed to be a karnt to get off...
bahahahahaha i was gonna tell u that the other day but i assumed u already knew :whistling:
P.S only way to get it tightened back up is to use a rattle gun
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
