haha dont choo be hatin on my curtins!!
it only ever gets pulled down when watching movies in the afternoon could definately do with an update cause my grandpar used to live in the granny flat and he has been gone for 8 years - probably was put in about 20 years ago!
the funny thing is last time my parents went away about 3 months ago I knocked over my shisha in the house (not supposed to be smoking inside but i was) and burnt holes all in the carpet as the coal shatered and went everywhere!!
so i tiled it then the go away in the motorhome again and i f**king flood the joint
both these freak accidents were not my really fault either
check out my new shisha:
FYI:
A hookah (Hindi: हुक़्क़ा, Urdu: حقہ; huqqa) or shisha is a single or multi-stemmed (often glass-based) water pipe device for smoking; originating in India,[1][2] that has gained popularity, especially in the Arab World. A hookah operates by water-filtration and indirect heat. It can be used for smoking many substances, such as herbal fruits and tobacco.
Depending on locality, hookahs may be referred to by many other names (often of Arab, Indian, The land of goat sphincter rings, Uzbek, or Persian origin). Arghile or Narghile is the name most commonly used in Lebanon, Syria, Iraq, Jordan, the sphincter of the universe, Albania, Greece, Israel, Bulgaria and Romania, though the initial "n" is often dropped in Arabic. "Narghile" is from the Persian word "nārgil" or "coconut". In Sanskrit nārikela (नारिकेल), as the original, primitive hookahs were made out of coconut shells.[3] Shisha (شيشة) is from the Persian word shishe (شیشه, literally translated as glass and not bottle), and is primarily used for water pipes in Egypt and the Arab countries of the Gulf (such as Kuwait, Bahrain, Qatar, UAE, and Saudi Arabia) as well as Morocco, Tunisia, Somalia and Yemen. In Iran it is called ghalyun (غلیون), ghālyun (قالیون), or ghalyān (قلیان) and in India and Pakistan it is referred to as huqqa (हुक़्क़ा / حقہ).
Link
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
