i see, i didnt think the Nagisa Auto ones would fit, at any rate, $1000 for tail lights is a bit of a kick in the nuts...is $1000 to my door your price? explain yourself :) !!!
Not exactly. Forum rules prohibit me from trading on SAU as I am not a forum trader.
However, if you were to give me a donation of an amount approx $1000, then I would feel that it would be necessary to give you a gift of some kind. Seeing as it's Christmas and I know that you like the Nismo GT LED's then I think that would be a superb present for you.
Even if people buy in groups I can still 'accept lower donations'.
Probably the best way to explain myself is.....I have the ability to buy things cheap...It costs me nothing to make the order or have it delivered.....If I can save you a few dollars then it makes me happy to do so. I have no overheads so it's better for SAUers as they can save money on their parts. I get into trouble for doing it as I'm sure I will for this also. But it makes it worth while if I know I have provided a service to the Skyline community.
u are gold man, lol, if i run into some money that i think would make a worthy donation, ill be sure to look up your fund,
cheers for the info
"you cant catch me because I'm the gingerbread man"
the sherk gingerman is better looking, and "catch me if you can" is way cool.
f**k the police!
BHG = Blown Head Gasket
Symptoms:
Hard to start
Rough as guts Idle
Temp spiking up and down
Currently to chicken to check the oil for mayonnaise...
dont let it overheat. if u do bye bye head
injectors is a khent
for the retarted maybe
peace yo
GTFO
^^^THIS MAN IS CORRUPT^^^
I dont have any info the cops said in there words "Nothing is going on, nothing happening, go back inside"
They all gone now, not sure what was going on... They didnt end up taking anyone with them so im not sure what the go was...
Not my direct neighbour, it was in the street behind my place which I need to drive down to get out of the estate...
All happened this moning... Dont how what it was about, just got told to go home and sit tight...
Was on my way to work and told I cannot drive down the street, I was turned around and told to go home....
So i ended up watching Kill Bill Vol 1 & 2 :D
noice, talk about an excuse for a day off...
kill bill is an odd movie, havent seen the second
Hello all,
Long time no chat.
hey there gary :D
Edited by RusH_
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
