OMFG that is just the most awesome weapon, and with the mini frag grenade just perfect, if I ever have to defend this country I want one.
whores.. also i hear noel ran a 1.09 around Clubman a few days ago.. not bad for a first time, but a while to go before he breaches the top 10: http://www.timeattack.com.au/top_ten/2wd-clubman.htm
Does everyone on hear have jobs??? wat is there to do in the middle of the day? i have been sitting on my arse now for 2 weeks doing nothing but watching movies playing, video games, and reading stuff. sooooooooooooooooooooooooooooooo bored. can't drive or walk for at least the next week, wat do the unemployed do with their time"????
ahah yeah done the porn, gave up weed ages ago, and i actually watched oprah yessterday and a bit of good ol Dr Phil don't think i can take much more at least getting paid to do it all thanks to work cover.
had a mate once that ate dog shit on a hot dog one night (he didn't know till half way through) no joke, thats wat u get for being a dumb assed stoner with the munchies. Big brother is lame can't believe they're gona run it again
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
