It was, and its gonna take me 3-4 hours tomorrow to sort out which cameras go in which box (serial numbers and all) and then list the missing lens covers etc etc...
Ive got an idea tho, ill go to the coffee club and get a half a dozen muffins and take away coffees and then dump them on the admin girls desks and get them to do it... :/
But I think ill still have to supervise, need a job done right do it yourself they say...
thought this was funny, my dad is searching for a new car, and we cam arcoss this $300,000 Bmw M6 for sale. chech out the other cars this guy owns... some poeple have to much money
http://www.carsales.com.au/Tig/UI/CSPhotoS...PortalID=240481
Hunt around a few brokers. I pay bugger all for the GTR.
I'd tell you who my actual insurer is, but they don't have many imports and so their premiums reflect that. Other insurers that have been stung with repair bills for imports have cranked the premiums up to ridiculous.......... so I don't use them any more.
i carry a shit load more speed through the corners as i dont slide all over the place like the lighter people...
no need for brakes, just lean forward and turn into the corner... bobs ya uncle im faster through the twists and faster out of the corners...
as you know go karts take time to build speed, so the faster you come out of a corner the better...
that all said, i came 1st for the day so who cares...
also i remember beating one "shanef" at kingston park a few years back in the rain... :thumbsup:
wish they would pull their finger and fu<kin fix your car
there should be no excusses as to why they are taking so god damn long
and no excusses as to why it failed in the first place, sounds to me like they are being chumps about it all
yeah pretty average mate
i raced in all three sessions... So i spent a good 3 hours in the drivers seat yesterday... heaps more drive time than every before...
i was just looking at the slips to see what times i was posting per lap and i noticed i did 181 laps of kingston park yesterday...
most sessions are no more than 15 laps each, but they let us cut loose for an hour straight as we had the track to ourselves, i even had to make a fuel stop as the kart started to cut out on me round the corners and i noticed the tank was basiclly empty... :thumbsup:
was funny having to pit to re-fuel at a go kart track... :D
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
