I was at that Go Kart night in the wet Col... Was funny watching Benji, Marc and Karen get in her car soaked to the skin... The boys stripped down to their undies...
LOL, yeah we had to get down to boxers, or we would have soaked out car seats and caught a cold... :D
Fun times... Remember the big puddle at the end of pit lane and through the 2nd corner, the seat acted like a scoop and all of a sudden you had loads of water in your pants...
Guilty as charged.
LOL, funny you know i was there to see some action and you came through for me... :D
Hi.
I was at lakeside too. Awesome fun day!
I heard that yellow 33 got down to a 60 sec time. not bad when I only got to a 62.58 in a gtr!
That day was a blast, you will see me there again for sure!
Hi.
I liked that supra over the yellow thing.
He was very quick, he kept pulling on everyone else in the group...
He was also very consistant through the last corner, as where everyone else seemed to keep pushing harder and harder this guys was very smooth...
question.. what aftermarket racing seat can i get that will sit lower than the stock GTR seat. The stock GTR seat is ok, but i wouldnt mind something thats an inch of 2 lower.. would make heel toeing a lot easier.
I've got an old bride fixed back seat with 33 rails you can have for $200.
It sits a bit lower
Get a Recaro with Skyline Rails. I have fitted 2 in the GTR. Lower than stock and handles my 115kegs without flexing like the crap stock ones.
Never bothered getting a time. It was supposed to be an 80% day as we establish ourselves on the track. If I never see that Yellow piece of rubbish again I'll be happy.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
