I spent my saturday fixing my air con, only to find the relay's are stuffed so even after refitting it all and re-gasing it the compressor wouldnt engage.
Got to love a spare parts collection, finally after 3 years its working properly
thats the one thing im loving about driving my bros are around atm - epic air con
except now i want to fix the 180s air con but have limited $$ ;)
oh and,
good morning!
except now i want to fix the 180s air con but have limited $$ :P
oh and,
good morning!
I'm loving the air con in the Brabus at the moment.
Doing it without is for suckers :(
hahaha sounds exactlly liek my saturday anna
im burnt where the sunscreen didnt go... :(
ahahahaha I put sunscreen on my truckers arm heading down there, but I made Andy drive on the way home and forgot to do my left arm. It was f**ked by the time we got home :-(
Oh i've gotta do the air con in the syl. When we pulled the old engine out, waz just ripped the hose off letting all the gas out...... now i've gotta have it switched to the new system so that's $200 I wasn't counting on *cries*
yeh its not cheap :P
however it is better than sweating it out in the middle of the day.. unless that sweating is with josh, naked
Yeh it does suck a dick. I hate getting in it when it's been sitting in the sun... black car = ass.
He's running, has been for 4 weeks now, no nasty noises (except the VCT upon start up) and he doesn't sound too much like a tractor, exhaust choice is important with sr's, get a shit one and you might as well be hookin around on dad's ride-on :(
Gotta get him tuned though, 4000 rpm limit sucks dick, i'm changing outta 1st when i'm barely off the line :P So when i've got some spare cash (before Drag day) he's going back to EFI :(
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
