That sucks hombre! Sounds like an interesting project.
Similar note: The airport now has an actual waiting bay and it's free for 20 min. To prevent people going in and leaving after 15 min and coming straight back, there's a camera that snaps your number plate as you enter. Interesting tech.
sick belly, need to be near amenities, lol.
nerdy stuff is an EtherTen board(arduino variant) setting it up and programming it to be a car counter for a driveway, but will ignore exiting cars, and ignore pedestians, while triggering a PTZ camera to pause its patrol, and swing around to capture the number plate of the entering car.
wait whats this ignore pedestrians so no upskirts pics?
I forgot to say that the counter once up and running, will be viewable from a web browser to see how many cars have entered that day, that year, and how many spaces are left
Nicely done. Sounds like some nifty engineering ther.
So jelly. I wish my job involved jet setting to Japan and getting to drive sexy JDM cars (she can keep that rental-Yuck!). I'd come back 10kgs heavier from all that awesome Asian food and trying to tell the gate staff that the 34 cat back system I have stuffed down my shirt is actually a very high tech spinal brace.
Thats ok im a great replacement
I dunno if my 34 ('The Ark') would like that very much. There is a single blonde Silvia driver in Victoria ;)
Milk bar is a term in some parts of Australia for suburban local shops or general stores. They are known as tuck shops, delicatessens or delis in South Australia and Western Australia, and as corner stores in Queensland and New South Wales. Milk bars are traditionally a place where people pick up milk and newspapers, and where school children purchase milkshakes or lollies.
Wadyaknow
they also used the term back in the 40-60s in the us, and here for the shops that sold milk shakes.
these were a local hangout/past time for youth.
I have also used the term for local take away shops that sell hamburgers and chips, etc.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
