Missed a whole day of work today. Back has been playing up something chronic. Couldn't get out of bed to grab meds! Just tried to sleep it through but when I moved my legs, it would hurt again. This officially marks that Winter is here!
Agreed I believe last night was the last that was comfortable for sleeping in jocks only. Will be shirt/pant sing it up tonight :yes:
Arrhhh cmon you bunch of girls....go to your local supermarket and get hold of some nice whisky (preferably single malt) that will keep you warm at nite ;)
that's the spirit (pun intended :turned: )
But seriously there's not a drop in the house and be f**ked if I'm gona cook t without some form of spirit in my hand in this f**k off cold weather
Also Autopro got my right wheel studs finally
Cooking without alco is a sin. You find you cook better with it.
