I dont remember no blonde.
I got one of a brunette, but no blonde.
Brunet would of been "Mary" or "Gigantor" I'd imagine... Either way I know I sent them to you, and u have a copy now lol
*names have been changed for whoretown acceptance ;), except in the case of Taylor as that name is the greatest name ever and should not be changed for anything lol
sup dude?
not much just the usual! last day of werk for the week! WIN!!!
met a cute chick on the way too so thats a bonus
Just at work man, sitting at le desk punching in 45000 accounts into this computer :(....
Also Luke its not rikki lake check your bloody phone!
See above
And we may get all the cool and obscure other cars for a reasonable price! bring on the end of aust holden and ford!
Did you know that Hyundai make a RWD V8 saloon? which I assume we dont get because it will steal more sales from Oldens and Fords
unbelievable prices aye? I think 600k is about as cheap as Ive seen a GT.....and 150k for a Mustang is just stupid. For that you can buy an epic old stang, at least then you have an excuse for being slow :)
turbo diesel ST_R
Skids to Rip?
If any chick I was dating or even (heaven forbid) married too asked me to sell the skyline, her arse would be out in the cold quick smart. But no chick will date me so all good haha
Same.
Who thinks Zeke should get a number plate saying CAPSLW?
Doooo eeeet!!
Hmmmm yeah but how about fake plates?
Funny thing is, he won't be using them to run cameras! Lol! :P
long day was long.
whats been happening?
Well...
Fark all...long day was also long, tomorrow is going to be even longer :unsure:
Actually...
lol yeah hi im damo! im just going to take a pic of you so i can sext everyone from WT
only pics i take at 4am with her you wouldnt be seeing :P
pics or ban.
anyways, went out last night to celebrate the big boss' 20th anniversary in the game. Got abso-fu**ing-lutely blotto and ended up at a strip club. The good ol' Cabaret Club - which actually had some remarkable talent last night. Saw a nerdy girl with the glasses and big b00bies. Then I decided that I wanted a nerdy girl. NO FRIGGEN NERDY GIRLS AROUND!! Not happy willy! :P
Still wrecked as all fuark!
do it.
use the line, I need a photo of you because you are my cousins doppelganger and no one would believe me without proof.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
