It's a random thread for talking shite. Very little useful content more like an ongoing conversation.
Just give nick shite about the LS1 and were all good. :)
Get faurked maxima owner :P
How bout u introduce yourself mate I.e name, what car you have and I believe Cap will fill u in on the rest :)
Yep well ahead of you Ant man, there's not alot of questions that need explaining but all of us whores welcome you :)
*except for Luke, Luke hates you :devil:
Only your R33 could offer you more love... Are you north or south side?
northside :)
i would love to meet more people around my area, i know there is a white 32 and a black 33 gtr like 1km from my house
Well that's good, Half love... The most love a man can hope for lol
half from you guys and the rest from my skyline :) full loved :)
spun bearings.
seized motor.
dirty 30 coversion.
ran out of money.
problems with manifolds.
started july last year.
just starting to get close to finishing now.
dirty 30 conversion?
what is wrong with the manifold?
dirty 30 is a term given to when you use an rb30 bottom end from a vl or older skyline, put a twin cam head(25/26) on it.
The manifold problem, was that for the size turbo I chose, the cheaper stuff didnt fit.
turbo fouled and bonnet didnt even come close to closing.
so dirty 30... make more power or? not really
that sucks about the mani. do is supra style.... cut your bonnet up with a nice big dirty hole and pod straight on the turbo hahaha :no:
Edited by cowdy
more torque, nicer to drive around town.
and giant turbo, more powah!
extra capacity helps spool the turbo.
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
