I have seen in and watched the video it looks pretty nice. But nothing will compare to seeing it in person.
On another note I am really sick of this hoon label. Driving home a swift was going 70 in a 60 zone. Red p plater. Then there is me 60 in the 60 and I get pulled over and I asked why me not the swift it was speeding she said your in a hoons cars. I'm like "that's offensive. It's an import and I do not hoon I just like this certain car. I could do more damage and get away with it in the Swift than this. I would do one chirpie in this and get it impounded."
She replied with "ill be back." Went back to the car came back and was like have a good night and got back in her car
SHE DID NOT!!!! WAIT.....SHE TOTALLY FARKIN DID SO!!!!
Wtf is wrong with those guys in Blue????
That just sh!ts me to hear that. Did they even RBT ya?
Otherwise they had no right pull you ova bro?
Dont say that.....Nick might be knockin on ya door :P
ill be waiting... with a chev bagde5974429_orig.jpg?300
nope she didnt. 3rd time pulled over only been rbt'd once, i got her officer name and number im making a complaint tomorrow.
Edited by cowdy
That's rough mate. Downright discrimination IMO.
Knock? What's that... Just barge in lol
That's da way Cap....you show em who's boss.
hahah i applied for an exemption with the moderately powerd. a 19 year old engine from 180 at the fly was down to 167 so it equald out to like 124.5kw per tonne
so to be safe we sent in the power from the wheels so it was 83 per tonne
have a look at it you might be able to get it for yours even though its a v8.
how long is left on your p's? if its less than 3 months its just worth waiting
night ants
Or 2 weeks and 54 minutes :P
Not that I'm counting or anything
hahahah not at all
i just still cant belive im allowed to drive a turbo 33. when i got approved i was like yelling and screaming and yeah like a p plater that can drive and afford a turbo car
hahahah not at all
I fuarkin hate you, I spent sooo much money on my NA f**kin r33 because I couldn't have a turbo at all. If I was allowed a turbo I would of had a nice forged 25 with a spastic laggy turbo and a C4 auto :(
.... Oh well, I've made what I've made no good being angry at the past
im looking in to how to fit a s15 6 speed manual in mine. and takinf out all the dampening lines in the clutch
you like your autos dont you...
Why do u want the 6 speed? What's wrong with the 5 speed in yours or is it an auto?
And yes I love autos, for numerous reasons... 2 mainly: people ALWAYS will underestimate an auto car (if they're misinformed nimrods) and nothing amuses me more then taking someone for a run in mine and watching them go "WTF as it smashes into the next gear" or better yet all the "manual heros" that lay shit and then make excuses when they can't launch and "miss gears"
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
