OI! Don't lie Kathryn your still first year....
Unless you forgot to mention to me you went second year :S
Secrecy man she's trying to undermine you from the inside out :/
You almost earn more an hour then I do and I am trade qualified. I work 45 hours per week and sometimes work 50 plus
Hehe, I'm on 23.40 ;) .... If I work a Sunday I can make almost $500 in one day :P
The chair matches my hair :P hehe
My hair aswell :ph34r:
Morning all
She is an apprentice electrician :P
Oooh.. Can see where this is going.
Don't do it Kathryn! Run while you still can!
He would know.
Red Bull.... that stuff does da trick in heartbeat.......also can kill you're heartbeat :P
Yup. Exactly.
That's because it's a Chevy....
Liking you already
Not if you work for the right company :)
When I was school based I was on $16 an hour doing 56 hours a week and my max pay was $1200
Affirmitive action. Females are required to be paid more in trades based roles. Govt plan to get moar wimminz out of the kitchen.
I'm a second year female apprentice who earns $19 an hour doing 38 hours a week :P
Kathryn my dear u r on a really good wicket.......NEVER, NEVER quit that day job.
Morning all
Public holiday here, woot!
Very jelly :(
Chris ditch dat job and com work 4 me as I need a sexetary :P
Edited by Ants
I think your public holiday is next Monday, Anthony
Woo hoo!!!!
Yep, almost MALE stripper money on Sundays... Mates call me a tight ass as I don't spend anything e except for on the car, alcohol, rent, telephone, food and insane electricity bills
better
f*kien electricity bill that was full of gaids... And yer dropped like $200 Saturday night :/
Nick - you gotta become a hermit and not go out and just drink yourself crazy at home - problem solved.
Haha never, if I'm not out seeing people on weekends/most of the time I go crazy... I'm a socialite of the lockyer. :)
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
