A kite????? Sh!t I want ur life brah!
Breakie done in 10mins. Just washed, now gonna mow da grass, trim da hedges and pull some weeds :(
After that I'm gonna clean my old injectors and paint them in VHT wrinkle plus :)
should see my kite!
it's a p51 mustang kite.
nik has seen, and can confirm, is awesome sauce.
