Still at oldies, have discovered a few things:
Thing 1: my car hates the highway and is slip city with this converter :(
Thing 2: any thing over half throttle 1-2 gear change it it chirps the tires
Thing 3: mums lasagna is still freakin awesome
Thing 4: dad is an electrical genius as he fixed my window :)
Thing 5: Jaimi has gotten hot again
Thing 1: I broke my car through my own stupidity :(
Thing 2: Because my car is broken and not fit for street use the cops will hassle me
FYP :thumbsup:
What's your beer of choice ants?
this is what I usually drink (if I can find it)
Nastro Azzuro aka Peroni premium beer
this is the real McCoy and brewed and bottled in ITALY (not here)
gonna crack it open now after all this hard work so :cheers:
doesn't your car have a lock up convertor?
and whos jaimi?
anti-gay lock up converter to keep Nick straight!
jaimi is the actually Jaime Durie from Manpower :nyaanyaa:
beer tastes like crapolla
to bad for you.
Edited by Ants
