not sure where this is going
Except for Lions...the lioness get pissed off because lion penises have barbs.
This is where it's going ;)
Not what I was expecting... Was just going to say that it's my animal right to be shit in the sack. :)
I dare say these ladies have more curves than nik would like.
Got lots of those
That's it, real ladies not his giraffes.
I don't do giraffes
Have you ever seen animals have sex? The majority of the time the female seems incredibly bored.
*yawn*
I'm curious as to why you pay so much attention to animals procreating?
Who didn't know that? Why do you think Chants is always so frustrated?
Dude ur doin this the wrong way. Stop watchin animal sex documentaries and get human (non-gay) pawn that should assist and ease Chants frustration! Edited by Ants
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
