I agree, big boobs are nice but I also agree that the boobs need to suit the girls chassis. Emma Watsons boobs are a great size for her chassis in my opinion
Agreed well kinda, had to take the skyline to work this morning f**king useless diahatsu!
My clock looks like a japnese number plate, all your comments today are irrelevant.
How is this done? Getting a new phone tomorrow and wouldnt mind it :-). Will be my first non iphone since the iphone was released back in the day
In the office at work (Donga) and it is fridge like.
Walked into the office and feels like a pressure cooker!
Do want
Was too busy fapping to post pics.
Morning whores.
Same
Dedication to the cause.
