I have to produce tangible work, I just make sure I'm the only one that can do it.... Wana fire me, try it let's see you run you business muhahaa :devil:
See how your post count diminishes as you marry a Taylor Swift look a like (because we both know you will not have a chance with the genuine Taylor) , spit kids (not skids), have an intense full-time job and a mortgage.
Totally have a chance, she just hasn't seen my guitar skills yet
Wow. So much happens when I turn my phone off for a few hours.
Seems as though the "new generation" of SAU qlders have a lot to learn.
Looks like there's a lot of history and a lot of knowledge amongst you guys.
Anna doesn't seriously think that I'm a feggit does she? :( also, shame on everyone else for not recognising "impact blue" wankers.
Who's coming out drinking on the 12th?
me, no kids (yet), and my wife has more curves than taylor swift.
then again, the 1/4 mile has more curves than taylor....
still dont know impact blue, but im new here, so cut me some slack.
in 5 years, go off at me for bot knowing any of you guys.
Don't dis my Taylor, she came over the pa at willowbank the other day and tony threatened to break my knee caps if i kept dancing lol
Lol.......would love to meet you someday Luke. I'm sure your wife is wonderful as well (no joke).
Tony. There is a lot of history here, and it's important to harness as much of it as possible.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
