got an old 200L drum at home that i can fill these into. @ $1.18 p/litre why not load up! The killer is the travel too and from the servo, 200km round trip
200km round trip from Bribie? 1.18 is CHEAP!!!
I have work ute and racing patrol that travel constantly... :)
First time ive used E85 from the pump and not sucrogen... have a mate that uses E85 from the United Servo at Crestmead and has done for a year on his SR and had no problems with it and gets good consistent quality. That was enough to sway me to drive there to get it. unfortunately Creatmead is about 100km's from Bribie. Well Pacific Harbour anyway.. Cant wait for some results
cheers mang.yours closer?and I also need sleep.and I keep thinking ive got to work tomorrow.
Yes, mine is very close. Car should be ready by the next week to get tuned.............I better get in touch with my tuner I guess :)
Do is yours on the road now luke?
for a week now.
farking love it.
heaaaaps better off boost.
crazy when its on.
but as stated, cuts at 6k.
still getting used to the dog box.
ok going up through the gears, still learning down gearing.
for a week now.
farking love it.
crazy when its on.
Sweet
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
