for a week now.farking love it.heaaaaps better off boost.crazy when its on.but as stated, cuts at 6k.still getting used to the dog box.ok going up through the gears, still learning down gearing.
So want this.............so very much this.........
Really happy your enjoying it Luke. Post some pics up of it if you can.......I'm an engine bay perv so post that up :)
Mr ants what's cracking mate?Just took one of the skyline crew for a run in the abomination. He liked it lol
Came back from tip. Got rid of tonnes of crap from the garage inc old engine fan and interior floor matts from the skyline.
Making more room for the GTR when she comes back to me.
Also did the groceries straight after which was a mission with my 3yo daughter.
Lol re joy ride in A-bomb........you should start charging for rides.
Did you make sure you flushed out the radiator and put new coolant in it :P
No I didn't but I topped it up with coolant and added more water because the place she gets it serviced is sh*t! They checked nothing
Luke, your car is really hot mate. I love it ;)
Here is a pic of what my mech sent me yesterday
she is basically ready to be bolted back. I need to drop off Nismo Twin Plate Clutch and other drivetrain bits now. I also need to find some pipes to replace the a/f meters.
looking good.
Would bang.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
