I watched it yesterday too, managed to find a good copy :whistling:
Was a better movie than I expected, did nothing to stop me from wanting a charger or challenger
Does anyone here have any recommendations for the servicing of every day cars within a relatively close radius of the CBD? My sister is blowing up about having too go to far to have her cars done, She lives at new farm so the closer to there the better.
Any one got any experience with anyone in the area.
Lol,
Yeah as i've said to others, i think i'll always go and watch an FnF movie, corny as they may be with the 120 gear gear boxes and endless supply of oneliners i still enjoyed it.
This latest one seems to have filled the gap as best it can between all of the other FnF movies including Tokyo Drift.
That said, i'm a little unsure about Jason Statham... good actor, but doesnt seem like the movie franchise to bring him into.
I was alarmed at my number of posts too, If you combine here and SAUQLD, which are posts I would have made here had the other site not existed, I am at almost 30,000. What am I doing with my life :( lol
Anyone know what kind of laws govern the use of any form of Camber on a street car?
Survival of the fittest. If you have stupid camber and not enough tyre on the ground and can't get away, it's your own fault when the masses chase you with pitchforks and torches :P
Come now Tony, i'm allowed to be curious!
Besides, i would like to run a little bit of camber, just enough to assist the rims in tucking correctly when underload/cornering
At some stage i will probably get a slightly smaller offset rim, but it would be nice to have my current ones not scrub when climbing uneven driveways etc...
I've heard 3* is the most suspension places will dial arms in at... Weather this is true or not I don't know.
Also camber ftmfw, I run my front camber arms maxed out you know... For extra hectics lol. And my rears are fairly angled as well :)
downloading top gear now :)
Woo top gear night! :)
I don't think there are any laws on camber itself. HOWEVER. when looking straight down from above the car, the entire tyre (including at the bottom) must be inside the line of the guard. So having epic offset and using camber to tuck the front level/inside the guard, but leaving the bottom outside the guard, will not be legal.
Good to know.
I do need to get another set of rims at some point lol, when money permits...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
