Computer server issues......fkn annoying!!!
What do you use? Xero?
Aye, even more when you have a vendor that is supposed to deliver a product that is 30mil over budget and no where near done. Glad I am not the contract manager on that one.
Someone's rectum is about to be set alight!
Apparently MYOB is a pain according to a few people. Firm that I met yesterday won't use anything except Xero. If the client doesn't want to convert, they won't take them on as a client!
I don't mind MYOB. But this whole cloud thing is also weird. Only sophisticated clients are going to reap the benefits of IMO. Xero, MYOB Live Accounts and other a/c software programs are all adopting this but time will tell how beneficial it will really be.
I just want one that works right now. That's all!
There are some SMEs that treat their accountants like bookkeepers. Makes life difficult. If you do need an extra pair of hands, call
Ghost busters! :ninja:
thanks mate.
evening.
evening young Luke GTRwalker
on tripple j daily, they make this song out to be like its the best sh*t out, im like maybe from 15 to 40
ok
Hiya Luke. How goes the money pit?
BIG money pit!
Finally home :)
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
